front-end clunk/rattle
Old Sep 7, 2022 | 06:50 AM
  #71
I have 12 inch links on my HHR , no contact with the sway bar
Old Sep 7, 2022 | 07:55 AM
  #72
And?
Old Sep 7, 2022 | 09:50 AM
  #73
No contact with the LCA’s or the subframe
Old Sep 7, 2022 | 04:06 PM
  #74
I had 12 inch links and the sway bar left big dents on the LCAs. Changed to 10 inch no more dents.
Old Sep 7, 2022 | 05:22 PM
  #75
Here’s the post from my switch to 12 inch links
Today, I changed those swaybar end links.I installed Delphi TC5530 featuring
Enlarged ball pin for greater load carrying capacity
Cataphoretic coating for superior rust protection
Sealed, high grade rubber boot
Ah, peace and quiet!
New link top fastener , lots of room
Old Moog link 9.8 inch , see how the lower fasteners is above the LCA
New 11.8 inch link clears the LCA , this is with the HHR jacked up on safety stands suspension relaxed
Lots of clearance at the swaybar end with new link installed
Same here compressed suspension, note the swaybar end is above the LCA
Here the tires are on and the HHR is down off the jack and compressing the suspension
Clearance at the swaybar at the rear
And here between the swaybar and LCA , the black area lower left of the photo
__________________
Old Sep 7, 2022 | 05:54 PM
  #76
Old Sep 8, 2022 | 10:09 PM
  #77
My observation of the changing geometry when the steering wheel is turned is that the 12 inch links have more leverage in the lateral plane than the 10 inch. I blame them for pushing the stops, which permits the bar to move laterally and make contact with the LCAs.
I could be completely wrong, but I suggest frequent checks if you have 12 inch links.
Old Sep 9, 2022 | 07:36 AM
  #78
Agreed, I inspect every 6 months at oil changes , seasonal tire change.
Old Sep 9, 2022 | 09:42 AM
  #79
Basically what I am saying is that the link hits the LCA. Nothing to do with the height of the sway bar end. When the wheels turn left or right the top end of the link follows and the bottom end is supposed to rotate in the joint. The 12 inch link changes the geometry so that instead of rotating it pushes/pulls laterally on the sway bar with more force than the 10 inch links. After the stops get displaced the bar can move allowing the end link to make contact with the LCA.
That is my theory, anyway. Maybe something else causes the stops to move, I can't think of anything else.
Old Sep 9, 2022 | 11:48 AM
  #80
A sound diagnosis, Donbrew, I’ll keep my eye on the links.
chevroletlover
Maintenance and Upkeep
16
Jul 22, 2021 06:10 AM
taz3
Dec 11, 2014 05:09 PM
tucsondivots
Nov 29, 2011 02:16 PM
thegodfather
Apr 11, 2011 04:50 PM
frogstatic
Jan 22, 2007 09:09 AM
