Front end noise, not hub?
Old Oct 24, 2019 | 03:57 PM
FrugalAudio's Avatar
Hearing a buzzing noise from the front of the car. Begins at about 25mph. Follows vehicle speed (changes pitch), not engine speed. Doesn't sound or feel like a wheel bearing. Rides fine at city and highway speeds. Both my front hub assemblies were replaced within the last 20,000 miles. Is there anything in the hub other than the bearing that could make noise? Any other things to look for?
Thanks,
John
Old Oct 24, 2019 | 04:19 PM
Easiest thing to check is to rotate the tires and see if the sound follows or stays in the same place...
A "Buzzing" that follows road speed could be anything, really... even a loose body panel could do that. (Or the center cap on a wheel... thus, the rotate the tires deal)
Doc brown's Avatar
I'd still be looking at a hub although that seems odd if you just replaced them. In the summer of 2018 mine made a sound like a playing card makes against spokes when clipped to a bicycle wheel. I've never heard a bearing make that kind of noise before but that's what it was.
Other things are as Greybeard suggested.
Old Oct 24, 2019 | 04:31 PM
Yeah, my first thought was a loose splash guard or something hitting a tire. Can't see anything like that at first glance. Plan to rotate tires next. Just trying to think of things to look for.
Old Oct 24, 2019 | 05:35 PM
I've heard that description for flex pipe.
vogtrj
Jul 16, 2023 06:41 AM
BigT
Drivetrain (Excluding Engine)
15
Aug 8, 2016 06:03 PM
fastsuv
Dec 3, 2014 10:38 AM
Smoke Wagon
Oct 24, 2014 06:16 PM
sking1973
May 7, 2012 11:38 PM
