Front licence plate bracket
Old Jun 22, 2006 | 11:41 AM
Holmes Hot Ride's Avatar
Originally Posted by WHITEHHR1
does anyone else notice the back licence plate rattles and slides around
it only has two bolts on top not on bottom
That Happend with mine and the first thing I did was put foam tape behind the plate and it stoped.
Old Jun 22, 2006 | 03:30 PM
HHR DLYT's Avatar
I agree with Sindy. I told them to NOT not put that bracket on my car. I will put it on only IF I get the fix-it ticket. Just my
Old Jun 22, 2006 | 03:51 PM
SoCalHHR's Avatar
Much of the time the rattling is caused by the plate and frame hitting each other. I used double-sided tape to affix the bottom of the plate to the back of the frame and it cured the problem completely. For folks who don't like the empty bolt holes, here's another solution:
Pick up a set of License Plate Mounting Bolts (a couple of bucks at Pep Boys or Auto Zone), and install them in the lower holes. Next put a small rubber vacuum fitting plug over the exposed bolt threads. This will cause the plug to press firmly against the body - while preventing the bolt threads from doing any damage. Firmly mounted plate = no rattle!
Hope it helps,
Old Jun 22, 2006 | 03:56 PM
PhxHHR's Avatar
Hope it helps,
This would be ideal if all license plate frames had bottom holes! My wife got me an awesome custom-made frame that had top holes only. Like others on this forum, I, too, used some weatherstripping to solve the problem - no more rattling!
Old Jun 23, 2006 | 12:30 AM
ivtech's Avatar
I got Dynamat for license plates. A large piece goes on the plate and strips on the frame. It is solid now.
ufvj217
Mods - Exterior
11
Jun 21, 2011 12:39 PM
txbass06
May 13, 2009 06:36 PM
