front wheel hub replacement
I found this
11588890 - Genuine GM BOLT, Steering Knuckle Spindle
And this , just scroll down to part number 8
Chevrolet HHR SUSPENSION/FRONT
Looks like that the part number!
Maybe GM figured out that hard to get at bolt by using a smaller socket!
Keep in mind that with an 06 you may, and probably do have a lot of corrosion of the white metal on the hole where the hub fits on. I had to use quite a bit of force to get the hub out. Then take 100 grit sand paper and sand off all the corrosion so the new hub slides in easily.
