front wheel hub replacement
Old Apr 10, 2016 | 04:19 AM
BMAN's Avatar
Could be????
Old Apr 11, 2016 | 10:38 AM
Was it in a package with the part number on it? The part number seems to be correct, but if they store them in bins it could be misfiled.
Old Apr 11, 2016 | 11:59 AM
BMAN's Avatar
Don't know if this reply made it, so, the bag is marked 1158-8890, bolt, front wheel. By the way, I stated that it was a 14mm head but in fact it's a 13mm...........???
Old Apr 11, 2016 | 12:15 PM
I doubt the threads will fit. That's 2 sizes smaller. I don't remember the hex head being over sized.
Old Apr 11, 2016 | 05:35 PM
BMAN's Avatar
Well, it went in and is tight???
Old Apr 11, 2016 | 06:29 PM
  #26
That is odd
Old Apr 11, 2016 | 06:58 PM
  #27
Same shank size, just a different head size.
Old Apr 11, 2016 | 07:18 PM
  #28
BMAN's Avatar
Indeed!!
Old Apr 20, 2016 | 07:01 PM
  #29
I found this
11588890 - Genuine GM BOLT, Steering Knuckle Spindle
And this , just scroll down to part number 8
Chevrolet HHR SUSPENSION/FRONT
Looks like that the part number!
Maybe GM figured out that hard to get at bolt by using a smaller socket!
Old Jul 13, 2017 | 08:17 PM
  #30
SHawn45431's Avatar
Originally Posted by Doc brown
Keep in mind that with an 06 you may, and probably do have a lot of corrosion of the white metal on the hole where the hub fits on. I had to use quite a bit of force to get the hub out. Then take 100 grit sand paper and sand off all the corrosion so the new hub slides in easily.
i have a 2009 and its pretty rusty what technique did you use to remove the old bearings?
