Fuel Lines Drip... easy replacement?
Old Feb 17, 2020 | 08:36 AM
Amazing the huge difference in the CA and US offering! $83 from ebay US same vendor. https://www.ebay.com/itm/Nylon-Tubin...efc23467c5b36f
Old Feb 17, 2020 | 08:43 AM
Donbrew , that is the half kit that splices into the existing fuel and vapour lines with a union , that’s why it’s less expensive, it’s half the kit.
Old Feb 17, 2020 | 08:59 AM
dougcjohn's Avatar
This is the Line Kit that's being recommended... eBay & Store's Site,
Main Kit to purchase...
https://www.inlinetube.com/products/nfr0019
This was the 2nd kit (in addition to 1st) that I was questioning...
It states 06-11 HHR models... this is not applicable?
It looks like 1 line is a duplicate, the other one was questioned.
https://www.inlinetube.com/products/nfr0018
Old Feb 17, 2020 | 09:43 AM
That second kit is not applicable. Go with that first kit you posted.
Old Feb 17, 2020 | 09:51 AM
2009-2011 is FLEX fuel. So, something acceptable for FLEX is acceptable for non-FLEX but not the other way.
Old Mar 16, 2020 | 09:08 AM
dougcjohn's Avatar
Originally Posted by Oldblue
That's a fussy task... and Wow, those lines had several sections of heavy rust!
That was a poor Engineering decision to use steel and wrap in water retaining heat shielding and a plastic channel.
For a few pennies more... Nickel or Stainless would have prevented.
What's the consensus, should new "heat shielding" be wrapped in same exhaust muffler zone?
Equiped with my new QuickJack... I was looking forward to the Fuel Line replacement. (although, now NOT looking forward to 2 Panels if & when needed)
Technically, it's an easy task... but those chassis routing clamps are a bit fussy and getting that heat shield & insulation wrap removed in the upper corner was a bear!
The Hahn Exhaust made access to the corner & wrapped lines more challenging to remove. I tried to pull it off but had to cut the majority.
If I hadn't had the QJ height & arm access, the Fuel line connector on the fuel pump side & canister would have been a tough one.
I ended up cutting the old line in a several sections to ease removal and minimize risk of damaging or pulling on brake lines.
The new vinyl lines are great... but even they're a fuss to position up in the exhaust corner.
I will admit, they look better than the steel lines and actually follow the clamps nicely... hopefully that's a long time solution.
Quit last night at the last clamp going up to engine bay... needed to remove Air Cleaner & IC Charge lines.
The 2.0L Air cleaner box was another new ordeal for me... that's a fussy thang!
I've got 6 new Airbox Grommets on order... 3 for inventory if they're this fussy!
That's another poor design compared to other options!
Old Mar 16, 2020 | 12:35 PM
Well, it has lasted at least 10 years. They only guarantee 3 years. Remember the 60's when Chrysler dared to offer a free 5 year/50,000 mile warranty?
No need to over engineer.
Definitely insulate vinyl. You might consider some type of armor from road debris.
Old Mar 16, 2020 | 01:36 PM
dougcjohn's Avatar
Yep, very true! Good point.
Nice days to work on them too!
But we could remove the old, run a new line, fabricate the bends and have her out the door in 2 hours tops!
Cars rarely rust through now, just thought they could make the fuel lines similar. Better low cost material now a days.
I"ll see if my NAPA has any shielding, if not Internet. Was pondering the same, but read several forums to toss it.
Old Mar 16, 2020 | 03:04 PM
This stuff , they also have a felcro sleeve for fuel and brake lines
http://www.jegs.com/i/DEI/186/010403/10002/-1
this is the sleeve
https://www.designengineering.com/va...l-line-sleeve/
Old Mar 16, 2020 | 04:01 PM
dougcjohn's Avatar
this is the sleeve
Hey Thanks @Oldblue , yep found similar... I was looking at Amazon.
Amazon Amazon
