Fuel Rail
Old Aug 12, 2024 | 08:35 AM
fastsuv's Avatar
Fuel Rail
I'm replacing my daughter's 2011 HHR 2.2L engine (timing chain jumped causing engine damage) with a 2.2L from a cobalt.
The fuel rail on the old 2.2L (and on all HHR 2.2L engines I have seen) has a rectangular cross section:
The replacement engine has a circular cross-section fuel rail. The injector harness connector and the fuel line connector appear to be the same.
Should I switch the fuel rails, or is the Cobalt engine fuel rail going to work just fine?
Thanks
Steve
Old Aug 12, 2024 | 08:51 AM
I would change the fuel rail , flush it out and clean any debris out of it.
Old Aug 12, 2024 | 09:12 AM
PulpFriction's Avatar
They’re different injectors; the HHR is FlexFuel, the Cobalt ain’t. You need to swap in your old injectors. Best way? IDK.
Old Aug 12, 2024 | 10:14 AM
fastsuv's Avatar
In that case, I need to order some Orings and other parts.
This is the Rock Auto 4-injector sealing kit listed for the HHR. I've never removed the injectors (or don't remember), so do these parts look right?
Thanks
Steve
Old Aug 12, 2024 | 10:15 AM
fastsuv's Avatar
Forgot to add, those are GM genuine parts.
Steve
Old Aug 12, 2024 | 11:15 AM
They are the parts , pull the injectors out with your HHR fuel rail, swap out o rings and insulator cups.
Waynejwj
Feb 10, 2016 11:08 AM
American Misfit
2.4L Performance Tech
23
Jul 17, 2012 09:56 PM
esmarkey
Feb 10, 2009 09:34 PM
Motormike
0
May 21, 2007 09:20 PM
DragonWagon
2.2L Performance Tech
11
May 1, 2006 02:30 PM
