funny noise
funny noise
The other day I noticed a funny noise coming from the front of my little ride.. it kind of sounds like something rubbing against the tire on the driver side, but nothing is there.. no rub.. the noise starts at about 30mph and seems to be a little whiny... I am thinking it is the transmission... i had an old ford that would whine like this when it was low on fluid or needed a band adjusted...
I checked the wheels, no play, no grind in the bearing...
If your sure its not the wheel bearing, check your lugnuts, then have your CV joint checked...could be a list of things from minor to major.
lug nuts
cv
out of balance tire
bad motor/tranny mounts
wheel hub/bearing assembly
are there any engine codes with this?
lug nuts
cv
out of balance tire
I only hear it when at speed... its hard to describe with a word...
kind of like the noise a card it the spoke of your bike... but not near as load....
It sound the same going around corners, the sound increases with speed..
no sound under 30mph
HHR321
Feb 17, 2007 11:18 AM
