Going through coolant
Old Mar 13, 2014 | 11:11 PM
babeba67's Avatar
2006 2.2L with 230,000+ miles. I'm going through coolant about 1 gallon every week (300 miles roughly). I had the oil tested and there is no coolant in the oil. There is not 1 drop on the garage floor after sitting all night. I'm guessing cracked head or head gasket although I'm not seeing the tell-tale 'white smoke' from exhaust at idle. The passenger side floorboard is dry so I don't think it's coming from the heater core, but I do "smell" the dexcool in the cabin and between fills I hear the sloshing sound of coolant at the dash.
What do you guys think? Next steps?
Old Mar 13, 2014 | 11:19 PM
Lucky's Avatar
My guess would be head gasket/cracked head. Some part stores sell a tester that tests for combustion gases at the coolant fill cap. It would confirm an internal leak.
Old Mar 13, 2014 | 11:23 PM
Lucky's Avatar
Here is the tester
Old Mar 14, 2014 | 01:45 AM
I'd have a look at the spark plugs. I'm thinking it's burning it if it's not going in the oil..
Old Mar 14, 2014 | 02:02 AM
X2 to the combustion gas test kit, and X2 to the plug check(look for one that looks suspiciously clean).
Plus, check your oil for a "chocolate milk" look and milky deposits at the top of the dipstick and under the oil fill cap.
And you might consider a compression test, plus pressure testing the cooling system.
Old Mar 14, 2014 | 02:04 AM
If you are smelling coolant in the cabin, check the inside of the windows for a build-up of moisture, or what looks like smoke coming out of the heating vents on the dash. The floor will not necessarily be wet if the heater core is leaking - the moisture may be trapped inside the heater mechanism causing the sloshing sound you hear.
Old Mar 14, 2014 | 02:08 AM
Or the sloshing/gurgling may be air entrained in the cooling system, it can be a "tell" when the coolant is low too.
Old Mar 14, 2014 | 02:13 AM
True that 843de. When the heater core in my other car went last fall, at first I thought I had a fire in the dash with the "smoke" from the vents, and the smell was nasty!!!!!
Old Mar 14, 2014 | 02:18 AM
I remember that, "The Revenge of The Avenger" incident, I bet your back is still sore from the under-dash contortions required to fix it.
Old Mar 14, 2014 | 07:53 AM
A other less catastrophic guess is water pump. The weep hole is on the top inside a well, so the coolant tends to kind of dribble and steam off rather than drip on the floor.
