Hard start when cold, no codes.HELP!!
I hope someone can help. My dealership is stumped. Starting yesterday, when I try to start my car, it tries to start, but takes several attempts before it catches then it stutters for about 15 seconds then smooths out. It seems that pumping the gas helps. It's not throwing any codes, no engine lights.
After it runs for 15- 20 mins, if i shut it off it'll start right back up but if it sits off for a couple of hours, it gives me a really hard time starting again.
![Lhhr2009 is offline](https://www.chevyhhr.net/forums/redzone/statusicon/user_offline.gif)
Sounds fuel related. No way to tell without really being there; they should have already tested the Fuel pressure at the rail both with ignition OFF as well as ON but not running. The pump may not be priming itself correctly and as it sits pressure slowly leaks. Could also be some fluky battery thing as EVERYTHING is electronically controlled these days. Ask the dealership what they have tried already and get back on here.
![aradmahogany is offline](https://www.chevyhhr.net/forums/redzone/statusicon/user_offline.gif)
Gotta ask.
Why did it get towed when in the 1st post you said it does start ?
Also, you said everything was fine according to the dealer. As far as codes, does that mean there were none showing ?
Fwiw. Posting the year, model and engine size would help us to give you an accurate opinion.
![firemangeorge is online now](https://www.chevyhhr.net/forums/redzone/statusicon/user_online.gif)
Is this a GM dealer. or a used car lot? When people say "dealer" we generally assume they mean "GM Dealership Service Department". The used car department at a GM dealership rarely uses the GM Dealership Service Department. There are different agendas.
Sounds like it's not maintaining fuel pressure when turned off. There is a check valve in the fuel pump.
![donbrew is offline](https://www.chevyhhr.net/forums/redzone/statusicon/user_offline.gif)
Dirty throttle body, MAF sensor, gunked up fuel injectors several other problems can cause the hard starting also wrong spark plugs, intake valve seal leaks. Purge valve .
All should throw a code , so are there any pending codes??
Last edited by Oldblue; 12-30-2016 at 09:14 AM. Reason: My spelling guru told me to fix an error!
![Oldblue is offline](https://www.chevyhhr.net/forums/redzone/statusicon/user_offline.gif)
If the "dealer" is NOT of the GM Dealership Service Department then run. Although pricey, my local one is DAMN GOOD at diagnosing issues. I had a hard start/ no start issue over a year ago that turned out to be a simple battery issue. I told the Service Dept. I thought it may be fuel related and they were honest enough to actually diagnose the problem. Sure I paid the "stealership" diagnostic fee, but they checked fuel pressure and everything for me, knowing it was just the battery, just to ease my mind. They could have just as easily sold me a fuel pump and I would have been none the wiser. Others here have had bad experiences, though.
Gotta ask.
It started right up for them. They can't find any leaks. No codes. And once you get it started it runs fine. But after you them it off and it sits for a few hours, it's really hard to start and is harder every time so whatever the problem is, it's getting worse.
