Headlight problems
A bad ground will cause the socket to melt.
Used sockets can have the same problem .
perhaps splicing in a socket from Dorman or GM
https://www.autozone.com/collision-b...637_53700_4147
Just to chime in, same problem My bulbs dont last. I know bulbs are rated by brightness and life span, and it is inversely proportional So do you want to see better at night or change bulbs less often. I have perfected bulb change. No need to remove as much as the book says.
Looking into the LED bulbs now
