Headlight problems
Old Jun 4, 2019 | 07:00 PM
Scott McCaslin's Avatar
Originally Posted by laylowcustoms
no one else has had this problem?
My problem is the socketsame keep burning up or melting
Old Jun 4, 2019 | 08:41 PM
Well, have you been replacing the socket every time it burns up or melts? How often is "keep"?
Come on, give us a bit more info that that. Have they damaged the headlight housing?
Old Jun 5, 2019 | 09:31 AM
I've replaced the socket (pigtail) about 5 times with ones I got at a junkyard.
Old Jun 5, 2019 | 11:34 AM
Have you checked the grounding with a VOM? If not, that would be the first step needed.
Old Jun 5, 2019 | 12:19 PM
What bulbs are you using?
Old Jun 5, 2019 | 02:02 PM
  #26
no i haven"t checked the ground but, that sounds like a good idea.
Old Jun 5, 2019 | 06:13 PM
  #27
guppy's Avatar
Which bulb are you using? Make and model number?
Old Jun 5, 2019 | 06:15 PM
  #28
Only If you are using one of the high wattage bulbs then that might explain the issue - however it would mean problems with both left and right. So I'd suspect the ground for sure.
Old Jun 5, 2019 | 06:53 PM
  #29
A bad ground will cause the socket to melt.
Used sockets can have the same problem .
perhaps splicing in a socket from Dorman or GM
https://www.autozone.com/collision-b...637_53700_4147
Old May 13, 2020 | 02:25 PM
  #30
Lee3333's Avatar
Just to chime in, same problem My bulbs dont last. I know bulbs are rated by brightness and life span, and it is inversely proportional So do you want to see better at night or change bulbs less often. I have perfected bulb change. No need to remove as much as the book says.
Looking into the LED bulbs now
