Headlights
Old Aug 23, 2013 | 08:56 AM
I had bulb issues, and found that there were issues with the seal where the bulb seats, make sure there is no dirt there or any part of the old seal, I cleaned up the seal seat and ensured I had the bulb seated in the new seal and my bulbs have lasted for 2 years so far
Old Aug 23, 2013 | 09:24 PM
On the HHR headlight it is very easy to miss removing the old gasket, then trying to put the new bulb in with it's included new gasket. If you don't realize what has happened you give up assuming that that's the way it is. WRONG! a. the light will not be centered properly. b. the bulb can vibrate causing the hot filament to break. c. leaving a plave for water to infiltrate.
You have to be sure that the bulb is securely locked into position. That is not easy to do, since you are working by feel with some pain, but vital.
colzdad
Sep 18, 2012 02:17 PM
hellfire35
Maintenance and Upkeep
Jan 29, 2011 08:52 AM
cva617680
Jul 30, 2009 08:35 PM
HHR_style
Jul 20, 2009 12:36 PM
Chevy_dork04
10
Feb 25, 2009 07:48 AM
