Headlights
Old Jul 31, 2013 | 08:46 PM
ltdoc's Avatar
Headlights
If I start the car with the key fob the right headlight comes on as normal. If I start the car using the key in the ignition switch, the right headlight never comes on, acts as if it's burned out. I've asked the local dealer about this and am getting a runaround (not uncommon since I didn't buy it there). I figure it's a computer related problem but no idea how to 'fix' it. Any suggestions?
- 'Doc
Old Jul 31, 2013 | 09:00 PM
Check the lights using the switch on the steering column, you may have a burned out high beam filament on the right side.
When in the DRL mode, the high beam filaments are illuminated at 80% voltage, so you can still have a working low beam filament.
Old Jul 31, 2013 | 09:06 PM
Just reiterating there is a difference between DRLs and headlights. Do your tail lights come on in one instance and not the other? DRL does NOT turn the tail lights on, headlights do.
dougefast24
Aug 23, 2013 09:24 PM
colzdad
Sep 18, 2012 02:17 PM
hellfire35
Maintenance and Upkeep
Jan 29, 2011 08:52 AM
cva617680
Jul 30, 2009 08:35 PM
HHR_style
Jul 20, 2009 12:36 PM
