Heater blows cold
Ok guys! I replaced the t-stat and coolant last Saturday, a week ago. Everything went smoothly. Just yesterday it started doing the same exact thing. It went a whole week nice and hot. I was on my way home from work last night, started hot and then again went lukewarm. Now I notice once it goes lukewarm, it tends to blow more air out of the vents, then once it goes back to hot, it slows down a bit, like it has a fluctuation in a door or something. My mind is boggled. What I don't get is, why it went a whole week without an issue. I would think the issue would still be daily as it was before i changed the t-stat. I did noticed that the seal in the t-stat didn't look good, so I thougt I nailed it.
Did you check the heater core like donbrew suggested?
And here's the link for the blend door again.
IF it turns into a blend door actuator issue, here is a link to the procedure. Thanks to former mod ChevyMgr.
Post #11 in this link: https://www.chevyhhr.net/forums/prob...m-33767/page2/
Yup, delco t-stat and dexcool. The temp currently is running between 183 - 198. I believe the temps before were in the 190's to 200
