heater /defrost AC issue
Old Jan 3, 2022 | 10:47 AM
honeyman's Avatar
Hello everyone, this is my first time post. I have searched and cannot find anything like the problem I am having, any help will be greatly appreciated.
2007 HHR only used occasionally, but recently when driving I turned on the heater and then the front defroster, as well as rear defroster all worked fine. Then I noticed it was getting very hot in the car. I could not turn the temp down and could not redirect the airflow to floor. AC will not come on the lights on the control switches for the climate control do not function now (they did prior to this time) all air flow is from defroster vent only , Fan speed switch works fine. This is one owner vehicle we purchased new. Only work done concerning heater /ac was leaves in the fan cover that caused noise, this was several years ago and no problem since then until now.
Old Jan 3, 2022 | 10:56 AM
Time to investigate the wiring, look at the hvac control panel for burnt connectors.
Old Jan 3, 2022 | 11:33 AM
honeyman's Avatar
Thank you I will check that out, but before I take out that control panel, I have a question could it be a fuse?or fuses ?
this happened while we were driving and If burnt wires I would think that I should have smelled it ? maybe not just want to make sure
before I proceed. Again thank you
Old Jan 3, 2022 | 11:54 AM
Yes it could be fuses or relays
https://www.chevyhhr.net/forums/prob...ocation-51667/
Old Jan 3, 2022 | 01:02 PM
honeyman's Avatar
Thank you , it has turned off cold for our part of the country. I will check them in the next day or two and update the thread.
Old Jan 4, 2022 | 09:44 AM
honeyman's Avatar
I want to thank those of you who took time to help me. Here is what I found, I removed the kick panel on passenger side of console and the wire/fuses seems to be a little loose.
I pushed all the connectors together and the fuses went in a tiny bit more and all functions returned to the control panel. So at least for now everything is working, thank you again
Old Jan 4, 2022 | 10:22 AM
Do the same to the under hood fuse box.
Old Jan 4, 2022 | 11:18 AM
Yes please^^^^^
Old Jan 4, 2022 | 04:42 PM
honeyman's Avatar
I will do that, thanks again
Old Jan 4, 2022 | 05:09 PM
You are very welcome. Thanks for the confirmation follow up!
Den
Jul 30, 2021 10:27 AM
Mike Montgomery
Oct 24, 2020 12:24 PM
kvnmccar
Sep 3, 2013 06:39 PM
HHRatRod
Jul 10, 2008 03:03 PM
ezeerider
Jul 3, 2007 05:08 PM
