HEEEEEELP!@?!?!?!? left signal out
Old Jan 20, 2008 | 11:48 PM
rebel8ball's Avatar
ok, put in new horn now the drivers side running light/turnsignal wont work, the parking lamp part works but no turn signal, no daytime running...and yes i changed the bulb, have no idea how to find the fuse as i didnt find a turn signal fuse, and i know there is no relays.... any help would be great.
Old Jan 21, 2008 | 08:49 AM
an08HHR's Avatar
fuse #31 under the hood is the running lights on the 2008 HHR. Nothing is mentioned in the owner manual for the turn signal? has #69 as parking lamps.
Old Jan 21, 2008 | 12:04 PM
rebel8ball's Avatar
ill check that, its weird cause only one side is out an donly on the front... i dont know if i messed up a wire in the plug, or the socket got jarred and went bad while we were in there or what, ive tried three bulbs and nothing... the only thing that works is the parking lights (when you turn on the headlights it comes on, the bright side of the bulbs wont light at all, might have to go buy a test and check it out but its making me
Old Jan 21, 2008 | 12:22 PM
GTOMIKE's Avatar
Did you use the factory horn wires or did you splice into a different wire.If it isn`t to big of a job you may want to put every thing back the way it was and see if your lights work again.
Old Jan 21, 2008 | 12:24 PM
an08HHR's Avatar
A fuse would cause both sides to go out. Better check the wires where you were working and see if one got damaged or something. Don't know what else to say . Good Luck . I'm now assuming things worked before, so now just undo what you thought you didn't do to do what you did that did it.
Old Jan 21, 2008 | 01:44 PM
rebel8ball's Avatar
yea not a huge deal to get to, just gotta take apart the inside of the drivers side fender...used the factory wires, only thing i can figure is either bumped the socket and messed it up or bumped a wire wrong.... just maddening...lol
thanks for all the advoce guys, btw the reason i asked about fuses, ours has sperate ones for each headlight...
RobV
May 28, 2015 03:56 PM
otacon
Jul 5, 2011 10:01 AM
trickss
Maintenance and Upkeep
Apr 5, 2011 03:40 PM
stephenm
Dec 2, 2010 04:35 PM
ummlee
May 15, 2009 07:33 AM
