Help.......
Old Feb 8, 2018 | 07:35 PM
Mark Black's Avatar
And can i drive it I've been no noise just setting code and running funny from time to time. Really need it inspected. What timing kit should i get ? Does it come with sprockets and water pump and seals. Idk where to get it done pep boys said if I get parts they do for 746 labor. Idk gonna call around I guess
Old Feb 8, 2018 | 08:33 PM
First you need to know exactly what is needed. Could be the tensioner just needs activating.
It is 5 hour flat rate, check eBay, gaskets are separate. Usually don't need sprockets, some include water pump
Old Feb 8, 2018 | 08:47 PM
Mark Black's Avatar
Well I guess when I pop the top I can try the tensioner they or if chain moves. How do I find out what's needed call and ask them what parts they need to do it
Old Feb 8, 2018 | 08:50 PM
Many shops will not guarantee the repair unless you let them procure the parts.
You cannot see the tensioner by removing the valve cover, you can only check if the chain is loose.
Old Feb 8, 2018 | 08:55 PM
Mark Black's Avatar
Yes got that pep boys said if I got parts cause they didn't have them that they would do it labor was 746. I can get whatever set will fit. I know I can only see the chain but I can tap tensioner see if pops to tighten chain
Old Feb 9, 2018 | 07:39 AM
  #26
Did you not see or read my post #3 back on page one?
Old Feb 10, 2018 | 01:30 PM
  #27
Mark Black's Avatar
Ok so driving around today light went off got it inspected and has stayed off now so idk.
Old Feb 10, 2018 | 02:09 PM
  #28
Ok, so we’re done , it was nothing at all. Don’t forget to tell when something breaks and takes your engine out to lunch.
Old Feb 10, 2018 | 07:15 PM
  #29
Mark Black's Avatar
Didn't say I wasn't getting it looked at. Just giving an update. Still plan on changing the chain
Old Feb 11, 2018 | 11:15 AM
  #30
Do it very soon and stop driving the car, the front guide could fail and damage the valves, is what I meant.
And
I don’t want you to damage your engine, that’s all
SpaceCowboy
Jan 27, 2012 02:28 PM
gotboost
11
Jan 20, 2012 07:30 PM
an08HHR
Apr 20, 2008 09:26 AM
NEXTIMAGE
Feb 8, 2008 04:26 AM
