Help
Old May 17, 2021 | 10:41 PM
David Garcia's Avatar
Help
Maybe someone can help have an 06 hhr 2.4 had the tc and check engine light come on after replacing a bunch of sensors scanned at autozone and got a replace cylinder head and gasket scanned again today and got the following codes p0300 and p0341 I recently replaced 2 ignition coils 02 censor purge solenoid any helps Is appreciated
Old May 18, 2021 | 06:14 AM
Vague information, the bunch of sensors? And what other codes?
P0300 is a generic misfire code, it could be loose wires , bad ground , wrong spark plugs the other two coils , the new coil is defective.
https://www.obd-codes.com/p0300
P0341 is a wiring problem and could be caused also be a bad ground
https://www.obd-codes.com/p0341
I suggest you stop guessing and throwing parts at it .
Inspect the wiring, any signs of rodent activity under the hood?
are the wires chafed near the EVAP purge valve?
any loose connections, corrosion in the connections?
Old May 18, 2021 | 08:36 AM
Yes, very vague. This is what often happens with voice-to-text. I can't tell what you've done, why you did it, or the order that things were done.
Please slow down, use complete sentences, and punctuation.
Old May 18, 2021 | 08:52 AM
Originally Posted by David Garcia
Maybe someone can help...........Yes we can help.
have an 06 hhr 2.4.......................What is the mileage on the car ?
had the tc and check engine light come on..............
after replacing a bunch of sensors scanned at autozone and got a replace cylinder head and gasket......What sensors ? What is "got a replace cylinder head and gasket" ?
I recently replaced 2 ignition coils 02 censor purge solenoid..........Why only 2 coils ? What is a Censor purge solenoid ?
Old May 18, 2021 | 01:21 PM
Now , there is a level of anticipation in the first post, can this thing be saved? Will it ever run again? I get the excitement in the text.
so take a deep breath and relax. Answer some questions.
Old May 19, 2021 | 07:39 AM
Doc brown's Avatar
Has the voltage on the battery been checked?
Old May 24, 2021 | 07:47 PM
Been a week.
Guess he's not coming back.
Just another "One and Done" poster wasting our time.
setyre
Mar 1, 2019 12:51 PM
Kmcvey10
Sep 14, 2015 08:11 PM
Mmgsxr750
Jan 15, 2015 05:55 PM
DaveEast
2.0L Performance Tech
Oct 19, 2014 11:24 PM
2007
Apr 18, 2014 09:45 PM
