HELP!!! brakes mushy...
Old Oct 19, 2018 | 11:02 AM
Cat Man HHR's Avatar
Originally Posted by whopper
What is the post about? Are you asking for further help or advice?
About all I can add is, if the ABS was working, you would have felt it, and HEARD it - so I have to assume that the ABS is NOT working.
The difference in the wear of the brake pads: nothing to worry about, the difference is pretty minimal, and can be caused by dirty calipers, guide pins and anything else the edge of the pads contact.
and if you used another QUART of brake fluid......... you really need to take it to a shop - using a quart (now what, 1.5 GALLONS?) is way out of line - you are doing something seriously wrong - you need to read the posts in this thread.
I'm out.
"The difference in the wear of the brake pads: nothing to worry about" I say the caliper piston is not retracting like it should causing uneven pad wear.
The amount of brake fluid that has been used was to flush out the system. That's the way I read it.
Old Oct 19, 2018 | 01:48 PM
That's what I meant by "incredibly bad".
Oh yeah, the pads were about 20,000 miles past their life. If the groove is gone the pads are worn out. Once they go that far comparing inner and outer is kind of worthless.
Old May 14, 2024 | 10:37 AM
Jaksback's Avatar
After I changed my rotors and pads with the car off I pumped the brakes until they tightened up to the pads but without opening the reservoir. Then I went for a drive and the brake pedal was mushy. The next morning I opened the reservoir then pumped the brakes until they were tight then recapped it. Went for a drive and the brake pedal was no longer mushy. Never opened the lines and/or bled the brakes. Everything is just fine now with no mushy pedal.
Old May 14, 2024 | 11:15 AM
Great now go and adjust the rear drum brake shoes!
Old May 14, 2024 | 11:16 AM
There should be no need to bleed of you don't open a caliper or cylinder. Just a pad change does not require it.
The reservoir is open to atmosphere opening it should do nothing.
Mushy after a pad change would indicate sticky slide pins.
Old May 14, 2024 | 03:25 PM
  #26
Jaksback's Avatar
Also adjusted. Only had to do 2 clicks each side. Didn't take apart the drum to see the wear though...save that for another weekend.
Old May 14, 2024 | 04:00 PM
  #27
A PSA , always remove the drum to clean and inspect the drums and brake shoes , and check the wheel cylinder for leakage!
Old May 15, 2024 | 08:48 AM
  #28
PulpFriction's Avatar
Had good pads and shoes, but pedal randomly dropping to near the floor. Braking while backing several times would fix it for awhile, so I concluded it was a problem with the adjusters. Had the garage inspect, clean, and adjust the brakes. Been perfect ever since.
Shellyw71
Aug 12, 2018 05:44 PM
Oldblue
Nov 24, 2013 11:18 AM
SpaceCowboy
Jan 27, 2012 02:28 PM
mrarff
0
Jan 7, 2011 08:15 AM
