Help- HHR Won't Crank but turns on
I have a 2009 HHR having the same issues.... all lites and gauges work when i turn the key on but the car will not crank at all... i have replaced the starter, the ignition switch amd the ignition key cylinders. I have also checked the starter relay and the battery and tried reprogramming the keys with no luck... I NEED HELP.... I NEED MY CAR!!!
There is no reason to try to repeat your problem in someone elses 2 year old thread.
Go back to your original thread/question if you're still looking for help.
I posted it here to see if the user could give me any insight since he is having the same issue... there no reason to be condescending but thank u
The fact is the user (or OP) hasn't logged back on to this site in 2 years. Doubt you'll get an answer from him.
I'm out.
