Car wont start but everything else works
Old May 15, 2015 | 01:10 AM
whoweth's Avatar
Unhappy Car wont start but everything else works
I have a 2009 HHR LT with the 2.4L engine. I drove it all day the other day thenm parked it for a couple hours. When I got back in it to go to work that night it wouldnt start. When I turn the key on all lights work all instruments work but the car will not turn over. I thought it was the starter but after changign the starter it still does the same thing. I checked all fuses and relays but they are all intact. Ideas I have had are Neutral Safety Switch adn ignition switch.. Can anybody give me any other ideas or tell me how to fix this. I NEED MY CAR!!!!
Old May 15, 2015 | 05:15 AM
Lucky's Avatar
Welcome to the site
Have you tested the battery? Is your car a automatic or standard trans?
Old May 15, 2015 | 06:07 AM
Battery, or ground wires loose
Welcome to the site
Old May 15, 2015 | 06:09 AM
whoweth's Avatar
Originally Posted by Lucky
Welcome to the site
Battery is good.... it has an auto trans..
Old May 15, 2015 | 06:12 AM
Then double check the ground wire connections near the battery and up front near the oil filter housing and at the rad cradle make sure they are clean and tight!
Old May 15, 2015 | 06:46 AM
whoweth's Avatar
I have checked all wires fuses and relays...
Old May 15, 2015 | 06:48 AM
Does the starter motor turn.
Is there any clicking and whirring?
Why do you suspect the ignition switch?
Old May 15, 2015 | 07:35 AM
whoweth's Avatar
Starter is good and as far as i know wiring is good... service manager at dealership said it could be the ignition switch... i don't have money to take it to shop so i was just asking questions and explaining what was going on.. he said ignition switch or neutral park position switch
Old May 15, 2015 | 08:41 AM
somebody else had this issue a month or so ago, it turned out to be his ground wire was burnt near the transmission.
Old May 15, 2015 | 09:40 AM
whoweth's Avatar
Even tho all the lights and gauges still work it could still be that ground wire??
