Car wont start but everything else works
Does the starter motor turn.
Is there any clicking and whirring?
That means : "can you hear clicking sounds (solenoid) and/or the sound of a motor running?" i.e.: is the motor getting 12VDC?
How did you test
all the fuses and relays
Has anyone messed with the OnStar module, if it is OnStar equipped?
Service advisers are not mechanics, they may have never owned a wrench. Don't expect their advice to be helpful.
I searched for starter circuit wiring diagrams but didn't find anything useful.
I assume that the ignition switch and neutral safety switch work through the computer which then controls the starter via a relay that would be fused. The cover should list what each fuse and relay is for and you could try swapping one relay for another.
