Car wont start but everything else works
Old May 15, 2015 | 10:11 AM
ground wires are different for lights than starter
Old May 15, 2015 | 02:15 PM
Does the starter motor turn.
Is there any clicking and whirring?
That means : "can you hear clicking sounds (solenoid) and/or the sound of a motor running?" i.e.: is the motor getting 12VDC?
How did you test
all the fuses and relays
Has anyone messed with the OnStar module, if it is OnStar equipped?
Service advisers are not mechanics, they may have never owned a wrench. Don't expect their advice to be helpful.
Old May 15, 2015 | 05:07 PM
whoweth's Avatar
U can hear it click when u turn key on but when u turn it to crank there is nothing... we jumped the starter and it would turn over but not start. The car does not have onstar...
Old May 15, 2015 | 06:03 PM
Here's a simple one. Have you tried another key ? Maybe the antitheft module is not recognizing the one your'e using.
Also. What about trying remote start ?
Old May 15, 2015 | 06:32 PM
I was not asking about clicking under the dash, I was asking about the starter solenoid!
This is way too difficult! Sorry, I can not help any more.
Old May 15, 2015 | 08:42 PM
whoweth's Avatar
I have tried different key and it is not equipped with remote start
Old May 15, 2015 | 09:37 PM
OK. Then guessing you have a 5 speed since the autos came with remote start. Maybe a clutch pedal position sensor problem ?
Old May 15, 2015 | 09:54 PM
whoweth's Avatar
No its an automatic... the remote i got when i bout the car was not remote start just keyless entry
Old May 16, 2015 | 09:16 PM
Don06's Avatar
I searched for starter circuit wiring diagrams but didn't find anything useful.
I assume that the ignition switch and neutral safety switch work through the computer which then controls the starter via a relay that would be fused. The cover should list what each fuse and relay is for and you could try swapping one relay for another.
Old May 16, 2015 | 09:18 PM
whoweth's Avatar
I have tried swapping relays.... still nothing
