Help w/Seat belt issues
Old Jul 24, 2020 | 10:58 AM
Jayjay6283's Avatar
I've recently came to own an 06 HHR LT and I noticed that I'm missing 2 backseat belt buckle. Where can I get replacement buckles for the rear middle seat and rear passenger seat? Also do I need a special tool to install them and is there a how to?
Old Jul 24, 2020 | 11:28 AM
Welcome to the site, send a PM to hellshotrod, he might have what you need
https://www.chevyhhr.net/forums/www....ad.php?t=63306
Old Jul 24, 2020 | 11:59 AM
You need a big torx, just simple bolt on, pretty high torque. Have you looked under the seat? Is this a panel that had rear seats added? If the bolts are missing you will need new ones, they are "special".
Old Jul 24, 2020 | 12:22 PM
fastsuv's Avatar
It's easy to accidentally have the belt buckles end up under the rear seat if the seat is removed.
I did that last time I removed the rear seat bottom and forgot to put the buckles on top before mounting the seat bottom.
I bet they are there under the rear seat bottom.
To remove the bottom, there are 4 plastic covers at the front of the seat. Remove covers and then remove the 4 bolts with the plastic cover retainers on them, noting the orientation of the retainers.
Or you might be able to tilt the seatbacks forward about 45 degrees and reach under the seat bottom from behind and pull out the buckles (what I did last time).
Steve
brownster
Jan 11, 2011 09:41 PM
American & Proud
Aug 10, 2010 12:13 AM
jim2893
Jan 31, 2010 08:15 PM
jerSSey HHR
Aug 3, 2008 04:45 PM
Old_Chevy_SS_Man
Jan 11, 2008 03:01 PM
