Help!!! Wont start!!!!
Old Nov 5, 2012 | 03:23 PM
Shanes0406's Avatar
So I recently had a Viper 791XVR remote start/
Security system installed in my 2010 HHR. a week later i go out and start the car and then i cant get the key out of the ignition cylinder. the car is in park and then i lose all power in accessory. now, i got the key out using the under the dassh plunger trick, but i still dont have any power when key is on. the locks work and the dome light works, but im not getting anything when the key is on run or start. then the key sticks again. is this a fault of the remote start, or is this a bad ignition cylinder? could it be a shifter linkage issue? or did my installer at best buy fry the BCM? please help..... STUCK AND CANT LEAVE!!!!!
Old Nov 5, 2012 | 03:24 PM
Shanes0406's Avatar
I also removed the Viper brain to restore the factory controls and still get nothing.
Old Nov 5, 2012 | 03:36 PM
Snoopy's Avatar
If you can MANUALLY move the gear selector to Drive and Park and the key is not removable, I would GUESS it is the ignition key/switch. IF IT IS, there is a couple of TSB/Service Orders in regard to this. It SHOULD be replaced free by the dealer.
However, if the problem started IMMEDIATELY after the alarm install, it could be that as well.
Old Nov 5, 2012 | 05:01 PM
Shanes0406's Avatar
i cannot shift the gear selector, it acts like it is not in park-but it is... i removed the key but i dont believe it is in the off position. also im still not getting power. Ahhhh! so frustarting.
Old Nov 6, 2012 | 02:57 PM
SpaceCowboy's Avatar
start using a multimeter and check your fuses...sounds like a bad ignition switch to me
Old Nov 6, 2012 | 08:53 PM
Shanes0406's Avatar
I found the issue. blown BCM fuse little 2amp.... thanks for the brain storming though...
Old Nov 6, 2012 | 08:59 PM
yay i win!
Old Nov 7, 2012 | 09:25 AM
wilkinsd1's Avatar
there is also a GM recall on that problem
Old Nov 7, 2012 | 03:12 PM
Shanes0406's Avatar
is there a recall on the 2010?
Old Nov 8, 2012 | 12:37 PM
@Shanes0406, send me a private message with the VIN of your vehicle and I'll be happy to look into recall data.
whoweth
Jul 1, 2015 03:00 PM
kalifdave
Feb 9, 2015 08:21 AM
PaperChaseHHR
Nov 18, 2014 03:19 PM
cccjoh
May 16, 2014 10:00 PM
upOnGamE
Oct 5, 2006 08:08 PM
