HHR died
HHR died
ok group I have a question for everyone I hope this doesn't brake any rules
my HHR just died all lights no start, any ideas
my Baby has 215 thousand miles and was running like a new car I am just puzzled
all recalls have been do battery is new red wire that I will have to check as soon as it stops raining, I think I have spent more money trying to get her running then I did for her but I cant tell her that.
Thanks so much
Bryan
I don't like working on new cars by the that would be anything after 1973
Thanks so much
Bryan
I replaced the terminals, checked all the grounds that I could find and replaced most of the dark gray fuses I tried to get a reading off my innova code scanner but nothing
I guess the car has to be running for that
Alright, you're going to have to state clearly what the problem is. You seemed to say that the car died, no lights work, no start? Now you're questioning the fuel pump?
And, no, the car does not have to be running to be able to pull codes. The fuse for the power port(cigarette lighter) is the same circuit as the OBD port.
Here is what happened day 1: pulled in parked turned off , started my truck turned it off went in the house
day 2: went out to go somewhere HHR would not start no crank no start no nothing
day 3: started checking fuses, changing bad ones, ordered new plugs coil pack somethings else
day4: change out battery and cables
day 7: all parts came in changed them all out rechecked to make sure everything was reattached
still nothing, I get lights inside the car like disco is coming back a lot of clicks but no start.
You I am not a mechanic I do upholstery and body and paint
I don't care much about amps, what about 12V? Should be more than 12.3.
Okay, not a mechanic, what do you think coils have to do with not cranking?
I know you understand a lamp will not light up if it is not plugged in? Same concept, not magic.
