HHR drain the gas tank useing the pump
No problem with splicing the gas and vapor lines. If you can crawl around under the car you can do that easily. Either with a short piece o rubber fuel line and a couple of stainless clamps or a brass compression coupler
No such thing as a "minor" exhaust leak especially in the winter. You are tempting the grim reaper.
Replace the fuel lines, not that expensive and fairly easy, you don’t have to drop the fuel tank!
https://www.chevyhhr.net/forums/how-...follies-62310/
