HHR Power Windows No Go
Old Jun 28, 2014 | 05:56 PM
outinthewoodsnf's Avatar
It appears that the key has to be on only for the 2 amp circuit,,, I still have the 9v at the door switch with the key off,,,I unplugged each of the BCM plugs and never lost the 9v at all, so that must come from elsewhere.... I was thinking earlier that the RAP relay may have something to do with it but the radio works with the key off till u open the door... Unless it has separate contacts for the windows
Old Jun 29, 2014 | 04:20 PM
Well, after 2 days at it, I gave up and ran another wire.... Works ok now,,, thanks to everyone who tied to help!
Old Jun 29, 2014 | 04:27 PM
OK. Gotta ask. Did you run the wire from a key switch source or the RAP ?
Old Jun 29, 2014 | 08:40 PM
Do I remember something about the "master" switch controlling the ground to all of the switches?
Old Jun 29, 2014 | 09:31 PM
Don't know donbrew. The schematic shows some sort of module in the master switch. It's labeled "logic" or something like that.
The schematic also shows just that one ground wire going to an under the drivers seat ground point.
But. Since the OP was able to just add a positive feed to the switch and it works, I would think the grounding circuit was working.
windsmith
Apr 26, 2015 04:19 PM
The bull
Jun 29, 2014 05:04 PM
edgarfrog
Mar 5, 2014 08:11 AM
aloppen
Nov 13, 2011 03:01 PM
Bullfrog
Jul 24, 2008 06:59 PM
