HHR putting and turns off at low speeds
Old Aug 24, 2019 | 10:46 PM
Benito Murillo's Avatar
Just curious.
1st post says it's a 2006 LS with a 2.4. Could you even get that combo model/engine back then ?
I fixed it, it's a 2.2 ls. The LT can have the 2.4
Old Aug 25, 2019 | 05:23 AM
Originally Posted by Benito Murillo
I went ahead and changed the sparkplugs since they were almost at 100000 miles and they were either white or black at the spark end. .
Just for clarification... Are you saying some were white while others were black? If so, did you keep track of what cylinders they each came out of?
Old Aug 25, 2019 | 10:21 AM
Oops I don't remember which one was white and which was black but I remember it was alternating. ie white plug, black plug, white plug, black plug.
I also noticed every time the engine putts it pulses like cabin lights with each one.
Old Aug 25, 2019 | 10:50 AM
Faulty engine ground
Old Aug 25, 2019 | 04:50 PM
Thanks you for everyone's help. I just checked the codes since I just got home from work and it has a p0326 (knock sensor) bank 1 code pending. I also noticed the putting has become way more frequently as o was driving home
Old Aug 25, 2019 | 05:16 PM
That doesn't necessarily me the sensor is bad... It means it's sensing something bad.
Old Aug 25, 2019 | 07:30 PM
The P0326 means the ECM commanded spark retard at a given load and speed is more than the calibrated value. I.E.: there is a knock.
Old Aug 26, 2019 | 10:28 AM
Is there a way I can figure out the cause of this at home? It seems to only knock at idle and in first gear, then disapears at speed
Old Aug 26, 2019 | 10:59 AM
Check the knock sensor, is it tight? Connections clean and tight?
Old Aug 26, 2019 | 12:15 PM
The knock sensor is essentially a microphone. If there is something banging from vibration it will sense it as a knock.
brant petty
15
May 27, 2019 08:06 AM
Dhorning23
2.4L Performance Tech
Feb 4, 2017 09:56 PM
Dev Anthony
Mar 15, 2016 02:04 PM
goetylsd
Jan 19, 2015 10:11 AM
BogusOtis
Jan 1, 2014 08:38 AM
