hhr wont turn over ??
Old Mar 16, 2015 | 10:05 PM
Check the starting system relay to see if it activates when you turn the key to the start position.
Old Mar 17, 2015 | 09:02 AM
promod62's Avatar
if that is 1 in uder hood fuse box i here it click, also swaped relays around,,,,
Old Mar 18, 2015 | 08:15 AM
JLMaximus's Avatar
Any codes?
Old Mar 18, 2015 | 09:51 AM
Let's do logic now.
The starter does activate when a hot wire is attached directly to it.
The relay is clicking.
No electricity being sent through the relay? Is there voltage going into it?
If not, why.
Old Mar 18, 2015 | 04:56 PM
Lucky's Avatar
I agree. Time to do some voltage checks.
Old Mar 18, 2015 | 05:14 PM
Lucky's Avatar
Here is a starter wiring diagram.
First check for power at crank fuse if you have power then check for that same power at the starter relay.
Then we can go from there
Old Mar 18, 2015 | 05:41 PM
Badassbowtie just posted his HHR had a similar issue, his dealer claims it is a burnt ground wire but I don't know which ones or where
Old Mar 18, 2015 | 07:49 PM
badassbowtie's Avatar
Oldblue! Broken eyelet....front of transmission. caused higher resistance...caused wires to burn. do you have a flickering CEL by any chance?
Old Mar 19, 2015 | 05:24 AM
Well well well! The ground at the front of the transmission just below the oil filter to the right of the engine block, and follow that wire on up to the radiator cradle , both are 13 mm nuts.
Please double check them. I inspect mine every oil change!
g bonnes
Sep 2, 2015 07:04 AM
anthonybeatz22
Apr 13, 2014 12:54 AM
Farmers Daughter
Mar 31, 2014 06:09 PM
twatts28
Jun 28, 2009 07:59 AM
itschaboykenny
Jun 13, 2008 07:43 AM
