High idle
Old Jun 24, 2020 | 03:11 PM
Robert Spinello's Avatar
High idle
I had my 175k miles 2006 hhr 2.2 engine timing chain replaced along with new valves and head reconditioned. Now the idle cant be reduced below 1600. I was told its the throttle body..didnt idle high before the repair.
Old Jun 24, 2020 | 03:15 PM
Robert, welcome to the site. Seems, someone fiddled with that throttle body and messed up the throttle plate, try a battery lobotomy, disconnect the negative cable from the battery for a full 30 minutes to reset the computers, then reconnect the negative cable, this should reduce the idle and the throttle will relearn it’s settings.
Old Jun 25, 2020 | 10:15 AM
The battery disconnect was done. I was told the throttle body looked bad. Is this the problem? should I have the throttle body replaced? Its expemsive.
Old Jun 25, 2020 | 10:24 AM
Ok, so you disconnected the battery for at least 30 minutes, how is the car behaving now? It may take some time for the idle to get back to normal.
Old Jun 25, 2020 | 11:16 AM
RockAuto lists several throttle bodies for the 06 2.2 HHR. In the $100-150 price range. Not very expensive.
Old Jun 25, 2020 | 11:47 AM
4 bolts and the electrical connector
Old Jun 25, 2020 | 11:51 AM
Battery disconnect was done with timing chain replacement and cylinder head recondition, new battery. two weeks ago Idle is at 1600. Hasn't moved.
Old Jun 25, 2020 | 11:54 AM
Do the battery disconnect again, please. It’s worked before and is the least expensive fix, try it.
Old Jun 25, 2020 | 11:59 AM
OE is $300.00
Old Jun 25, 2020 | 12:13 PM
AC Delco from RockAuto, we have a discount code for you 53A77ED85F8609. Copy and paste that in the how did you hear about us window.
https://www.rockauto.com/en/catalog/...ttle+body,6472
qcswlal
Jul 12, 2024 11:24 AM
Optimistic
Jul 5, 2024 06:59 AM
Nakamura
Drivetrain (Excluding Engine)
28
May 16, 2024 08:36 AM
hhr06NJ
Aug 10, 2014 08:23 PM
hhrrws
May 15, 2013 10:33 PM
