Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
I have a 06 2.4l.I have recently installed a volt gauge. Most of the time its reading 14.5-15.5. On some occasions it will read 13.5-13.8.I have been addressing codes p102 and p0053 but haven't figured it out yet. I had the mass airflow and tcm changed by Chevrolet and o2 sensors changed earlier this year. Is 15.5 you much voltage? Could that be causing those codes?
