how to test remote receiver in mirror
Old Mar 23, 2018 | 04:13 PM
SteveMaine's Avatar
Meant horn blowing alarm. Must have been another senior moment in spelling. get a lot of the recently
Originally Posted by Cat Man HHR
Do you mean. Howling blowing alarm ?
Old Mar 23, 2018 | 04:28 PM
You can lock the door, without arming the system, by using the plunger on the top of the door panel. Then when you unlock the door, by putting the key in the slot and turning, the alarm will not sound.
Old Mar 23, 2018 | 05:07 PM
See post # 6 for the location.
See your Owner Manual to see how the alarm works. Basically if you lock with the remote you must unlock with the remote.
Old May 6, 2018 | 05:14 PM
SteveMaine's Avatar
Replacing remote receiver.
I need to replace the remote receiver #15835547 on my 06 HHR. Can't find out where it goes. Need Help Thanks
Old May 6, 2018 | 05:21 PM
2006 that was in the head liner near the mirror I believe, it the pillar at the drivers door
Post #3 will show y’all
https://www.chevyhhr.net/forums/prob...-module-59528/
Old May 6, 2018 | 05:37 PM
On a 2006 it is behind the driver side rear seat under the quarter trim. Just like where we showed you in your other post about it.https://www.chevyhhr.net/forums/prob...-mirror-60110/
Why do you think it needs replacing?
Old May 6, 2018 | 05:47 PM
Merged
Old May 7, 2018 | 07:02 PM
SteveMaine's Avatar
Bypassing horn alarm
I was going to replace receiver for alarm system. Found out most gargaes charge 4-6 hours to do it which I can't afford. Is there away to discount wire going to horn for alarm system . I have been looking at wiring diagrams but can't fiquere it out.
Old May 7, 2018 | 07:13 PM
You never answered any questions about this alarm you speak of.
If this is a stock system the RCDLR is not part of the alarm.
If it is a stock system the alarm is armed when you lock the doors with the fob or the lock all button on the drivers door. The horn will blow if you open the door with the key.
There is no special wire from the alarm to the horn. The body control module sends a signal toi the horn relay.
Old May 7, 2018 | 07:17 PM
SteveMaine's Avatar
My remotes don't work. when I lock the car from inside, all doors and hatch lock. When I open the door with key, alarm goes off until car is started.
