I have problem with my driver's power seat toggles.
Have not changed the switch (not in the budget, here in Canada through NAPA or GM it is about $100) but yes, the lumbar switch works fine. The main switch works fine too in all directions except when trying to move the seat backwards.
Similar problem. My wife's 2015 Trax has been experiencing issues. The power button on the driver's seat will move the seat back but rarely works moving it forward.
Until tonight, we could always move it forward after repeated tries but tonight there is zero forward motion.
Suggestions?
Suggestions?
Suggestions?
Suggestions?
There’s a Trax forum in here
https://www.google.ca/search?q=trax+...&client=safari
while it might be routine, check the switch, track obstacles, ground wire, continuity, fuses relays.
I suggest you you get more information from a specific forum for the Trax
