I have problem with my driver's power seat toggles.
Old Oct 3, 2016 | 12:04 PM
JimDaddyo's Avatar
Originally Posted by Lethal Tendencies
Did you change the switch yet. And does your lumbar adjusting switch work?
Have not changed the switch (not in the budget, here in Canada through NAPA or GM it is about $100) but yes, the lumbar switch works fine. The main switch works fine too in all directions except when trying to move the seat backwards.
Old Oct 3, 2016 | 04:08 PM
You might try inputting the part number on eBay search.
Old Jul 8, 2019 | 06:38 PM
gymnast46's Avatar
Similar problem. My wife's 2015 Trax has been experiencing issues. The power button on the driver's seat will move the seat back but rarely works moving it forward.
Until tonight, we could always move it forward after repeated tries but tonight there is zero forward motion.
Suggestions?
Old Jul 8, 2019 | 06:56 PM
Suggestions?
No offense but why are you asking here ? This is the HHR forum. A 2015 Trax is a completely different car, different wiring and most likely a different type switch. I would suggest seeking answers on another forum that knows your car.
Old Jul 8, 2019 | 07:22 PM
My general rule would be to look at the rails and gears for some sort of obstruction. But since it's not an HHR any thing further would be wild guessing.
Old Jul 9, 2019 | 07:44 AM
  #26
There’s a Trax forum in here
https://www.google.ca/search?q=trax+...&client=safari
while it might be routine, check the switch, track obstacles, ground wire, continuity, fuses relays.
I suggest you you get more information from a specific forum for the Trax
Lethal Tendencies
Dec 20, 2014 08:07 PM
manicrodder
Sep 16, 2014 05:04 PM
johnsHHRSS
Jul 30, 2010 05:45 PM
JJ_HHR
Apr 30, 2008 09:13 PM
Juli
Aug 7, 2006 04:28 PM
