Infamous Vague Code P1174
Old Jun 13, 2021 | 01:07 PM
Ronnie's Avatar
Hi y'all...it's been awhile. I have a new project that has been keeping me busy. We bought a vintage camper that we have been trying to renovate and make our own. It's slowly getting there. Anywho...
On my journey down to the lake late Thursday night...as soon as I filled my tank "Vixen" threw the P1174 code. I did a little research on the code. But I wanted to come here and see if there has been a consistent spot where the problem seems to be?
I remember when my spark plugs were replaced...oil was found. I haven't pulled the spark plugs yet because it's been a crazy hot, humid and a stormy weekend.
I caught a break Friday night. A severe thunderstorm was heading our way. I left to run an errand. When I returned a huge tree was down that landed where I had been parked.
I put my cowboy hat on the base to give perspective on how big it is! I had been parked under the trees to keep "Vixen" in the shade.
Old Jun 13, 2021 | 01:40 PM
There is a TSB https://www.chevyhhr.net/forums/prob...e6/#post377970
Old Jun 13, 2021 | 04:45 PM
Hello, Ronnie, nice to see you, glad you moved your HHR! As for that code read thru this also
https://www.chevyhhr.net/forums/prob...balance-43947/
Rockauto has the injectors, I recommend the AC Delco parts,
https://www.rockauto.com/en/catalog/...+injector,6224
of course you can possibly get a ey of 4 for less on EBay
Or you can simply clean the injectors.
Old Jun 13, 2021 | 05:31 PM
Ronnie's Avatar
Thanks for the info guys. I will definitely look at all of that.
I forgot about the other issue I have been having. The A.C. will blow cold and then warm air. Is that a confessor issue? My 🤠 had put Freon in months ago. So I'm confident that isn't the issue.
Old Jun 13, 2021 | 05:46 PM
If your friend put freon in, then it must have a leak for it to have been low.
If the leak wasn't fixed, then it may have leaked down again.
Old Jun 13, 2021 | 06:05 PM
Low Freon must be investigated, checked for leaks. It might be a compressor issue, or a joint oring leaking, could be a pin hole in the condenser.
Either way have it inspected, first . Don’t waste Freon
Justtinkerin
Feb 2, 2024 04:14 AM
karenann
Jul 8, 2015 08:32 PM
Romulet
Jan 18, 2015 06:52 PM
edgarfrog
Oct 25, 2013 08:43 AM
LtGhost08
Jun 10, 2013 02:13 PM
