Inside windows
Old Jan 2, 2008 | 06:04 PM
stu1011's Avatar
Inside windows
Ok, it's cold. Does anyone else have the problem with the inside windows frosting up real bad? I have to start the car up, let it run to defrost and I end up with water and water streaks all over the inside of the windshield and side windows. Plus, I traded in a 2002 Ford F150 that got 14mpg, to drive a 2007 HHR that gets 19mpg. Some trade off.
Old Jan 2, 2008 | 06:29 PM
Black Rose's Avatar
Yep. Are your carpets wet?
That's what caused my frostup.
Old Jan 3, 2008 | 06:51 AM
No problems w/ Dory. But then again, in Miami there is no frost on any window--inside or out.
Old Jan 3, 2008 | 09:39 AM
an08HHR's Avatar
https://www.chevyhhr.net/forums/show...ghlight=carpet check out this thread. I agree with Black Rose.
Old Jan 3, 2008 | 11:14 AM
GCarp's Avatar
I had real bad moisture on the inside of my windows too when I had "The Leak" too. It went away when I got the leak fixed.
Old Jan 3, 2008 | 11:23 AM
Me too!
Old Jan 3, 2008 | 11:26 AM
Snoopy's Avatar
Hey stu1011....
Did you post this same question on another forum? If so, did you perform the suggested solutions given?
It appears that the same resolutions are given here. Check for EXCESSIVE moisture retained on the inside of the vehicle.....most likely, as others suggest, a leak in the cowling area to the upper and lower firewall and floor carpeting.
Have you discussed this iisue with your dealer???
Old Jan 3, 2008 | 04:10 PM
stu1011's Avatar
First time I have posted this. Sorry.
Old Jan 3, 2008 | 04:21 PM
stu1011's Avatar
Me again. The only moisture I have in the carpeting is the melted snow that fails to stay in the all weather floor mats that were made for the car. No leak here. Maybe its just that causing this.
Old Jan 3, 2008 | 05:18 PM
Snoopy's Avatar
Ok..just checking !!! So you're the second owner (I know of) that has mentioned this problem. The other owner, on another forum, is in Illinois also.
If the condensation is freezing to the INSIDE of your windows, I would think there must be excess moisture someplace. It's a lot of work and a pain but, I would try removing and emptying the moisture from the mats, maybe even towel drying them. If your problem doesn't correct in a few days, then I would check elsewhere.
I guess you're down to a process of elimination.
Keep us informed.
