Key Fob Problems Cheap Fix
Old Sep 1, 2011 | 11:35 AM
Originally Posted by wraunch
How hard is it to solder the contacts back on? I have one fob that I dropped and the contact on one side broke free of the solder.
Check this link out for the solder repair. It's pretty easy to do.
https://www.chevyhhr.net/forums/show...ht=cold+solder
And here is a link to a process to replace the individual contacts inside the FOB, as well as other ways to renew the contacts - https://www.chevyhhr.net/forums/how-tutorial-library-21/repair-key-fob-remotes-worn-out-contacts-30813/
Best of luck.
Old Sep 9, 2011 | 11:21 PM
bk94si's Avatar
Originally Posted by db/sb
Rather than buying a new key fob just to use the rubber pad you could try one of these. It worked on ours: http://www.keylessfix.com/keylessfixcom/
Thought I would just check back into this thread. I just installed 2 of these and they are great. Even on the remote that was working ok, you don't have to mash the buttons down to get them to work. I'm a happy camper.
Old Sep 10, 2011 | 01:45 AM
HHR01844's Avatar
so thats whats happening to my key fob? cause i hafta slap it against my leg or hand to get it to lock and unlock my doors....its getting old!!!
Old Nov 2, 2016 | 11:22 AM
Railpast's Avatar
FOB PROBLEM SOLVED: After doing all the above it still did not work although the horn button still did. I tried everything and knew it was problem with the rubber button as I believe it is the air pressure that activate the circuit. I held my finder over the spot where you put a coin to open it. After a little experimenting it seemed this solved the problem. Open the fob and clean all surfaces where the rubber contacts. I then sealed that hole and the top seam of the two halves. Works perfectly now. Use a contact type clue that even after dry remain flexible. Hope it works for you.
Old Nov 2, 2016 | 11:40 AM
No air pressure involved. Those small black dots on the back of the rubber pad are carbon when they contact the gold "Chinese writing" on the circuit board a circuit is completed.
I believe that you cleaned the contacts, that is what fixed the fob.
Old Nov 2, 2016 | 01:30 PM
Ad Donbrew says, "air pressure" has nothing to do with it. Absolutely nothing.
And now that you have used a "contact" type glue you likely can never pull it apart for a subsequent cleaning or repair.
Warning to others: Do not glue your remotes shell casing together.
That is bad advice. As long as the circuit board inside is good, you can replace the rubber pad and the casing at most auto parts stores. Often just cleaning the contacts on the pad and the board will help for a while, or resoldering the battery harness if it has come loose.
Just do not glue the case together.
Old Nov 2, 2016 | 04:52 PM
I think Railpast used the wrong word for the glue, contact cement is not flexible. Silicone glue would be. But there is no reason to seal the edges of the case; what about the huge holes that the buttons come through?
Old Nov 2, 2016 | 06:37 PM
Railpast's Avatar
Glue No Go - Plan B
Okay before everybody gets carried away. The contact cement I used remain soft even when dry and I only glued the top part. I thought it was fixed but did work then quit again. I had no problem opening it.
If the circuit is completed when the small carbon disk touches the circuit board is it possible the are no longer conductive? I cleaned both the circuit board and the black disk but still the same. As I mentioned the unlock still works after a couple clicks and the alarm horn right away.
Thanks
Old Nov 2, 2016 | 06:50 PM
Railpast's Avatar
One other question, coul it be an issue with the sensor in the car?
Old Nov 2, 2016 | 06:51 PM
Check on eBay you can get a new pad and case for less than $10. Pads for less that $5.
I glued a tiny piece of tin foil from a cigarette pack on the dots.
hhr remote key pad | eBay
If pressing on the case seems to make it work, I would suggest the battery cage may need resoldering.
https://www.chevyhhr.net/forums/%22h...ghlight=keyfob
Hint: the site search does not like 3 letter words, use "keyfob". There are at least 50 related threads.
