Key stucked/Microswitch works
Old Jul 19, 2014 | 07:22 AM
Odi's Avatar
Odi
Hi folks,
a have the known problem that I can't get my key out of the ignition.
I checked the microswitch it's doing what it was built for, it releases the white plastic thing at the ignition lock.
But I can do what I want..the key stucks in that damn lock....
Does anyone here has a fix for that issue.....I know there is recall according the lock also here in Germany.....but things here in Germany are a little bit slower....I called GM talked to my dealer the only thing they tell me not to put heavy stuff on it.
I guess there is inside of the lock something broken what prevent's the key to get out of the lock. Means my lock is broken...or I'm wrong...any ideas....
Thank's Oliver one of 1000 HHR driver's inEurope
Old Jul 19, 2014 | 11:25 AM
check out post #4 and #5 - https://www.chevyhhr.net/forums/prob...uck-key-37526/ re: removing the little cap under the steering column housing and using the key release lever. It may help.
Old Jul 19, 2014 | 05:47 PM
There is more than one interlock switch.
Old Jul 20, 2014 | 04:06 AM
Odi's Avatar
Odi
I can do with the release lever what I want....it just don't releases the key...
Is it maybe possible that there is problem inside of the lock....anythng broken...
lasater
Nov 24, 2013 03:38 PM
topgunn
Jun 21, 2013 06:51 AM
mmscuba
Aug 23, 2011 07:49 PM
blue car
May 17, 2010 02:31 PM
Ern
May 9, 2007 12:50 PM
