LEDs as plate bulbs
Old Jul 23, 2014 | 06:27 AM
Originally Posted by kornellred
LED's are semiconductor devices that need current limitation. Resistors are the prevalent way of limiting current in a DC circuit. As long as the current running through an LED does not exceed the maximum allowable current figure for a particular LED, the device will continue to operate for a long, long time.
It is highly likely that LED's manufactured specifically for incandescent bulb replacement in automotive applications have a resistive element built into the plug which guarantees current limitation - or else the installation instructions that come with the device should provide clear guidelines on what is necessary to achieve correct operation.
Isn't that exactly what I said?
The fact is that the suppliers think that if you are ordering it, you must know what you are doing so they don't bother printing anything.
Old Jul 23, 2014 | 07:12 AM
skyline26's Avatar
so how do you explain people who run LEDs without resistors and they work fine for years....just lucky?
Old Jul 23, 2014 | 07:18 AM
"Maximum allowable CURRENT".
Old Jul 23, 2014 | 07:21 AM
skyline26's Avatar
so how do we know what the max current is? are there LEDs that take more current then others and work fine without resistors?
Old Jul 23, 2014 | 03:41 PM
Specs are published.
Depends on your definition of "works fine". I would prefer to have them "work as designed".
Old Jul 29, 2014 | 10:57 AM
skyline26's Avatar
screw it. i put in regular bulbs
gio89kid
Mods - Exterior
16
Jul 17, 2015 12:18 AM
rkstevens
Jun 16, 2014 12:07 AM
skyline26
Maintenance and Upkeep
Nov 16, 2012 06:56 PM
slinginit
Feb 23, 2007 03:49 PM
SuperCelica00
20
Jan 9, 2007 08:37 PM
