Light problem?
Old Jul 20, 2016 | 05:21 PM
Maybe you should clearly re-state what the problem is. Started off bad DRLs, now you say bad turn signal?
Old Jul 20, 2016 | 07:15 PM
Originally Posted by Drifter.
Correct, the bulbs are the DRL on this year.......Da.....got that part figured now the left turn signal does not work, the bulb is good has power to the socket but nothing when switch is on, so my next guess is the switch is bad or BLM. I am going to buy the switch this weekend unless I get some new ideas from you guys. Thanks!
I am confused again!
There is power to the bulb, but the bulb does not light; so you think the most expensive thing is the problem?
Be sure to get the correct bulb 3157, the guy in the parts store will tell you "they are interchangeable"; let him buy you a new housing after it melts.
relay #68 fuse #69
One of the filaments (looks don't count, continuity and resistance do)
contacts on the bulb and socket (the corrode)
Then multi-switch.
Old Jul 24, 2016 | 01:20 PM
Drifter.'s Avatar
OK, my left turn signal does not flash, I have changed the bulb, the fuse is good, I checked power to the bulb, the running light has power, when the signal switch is turned on nothing. I checked voltage when switch was on no power going to the light.
What is between the bulb and the signal switch that could cause this? Are there other connectors I could check? Past experience with GM cars the signal switch is suspect when this happens??
If I could save the the 45 bucks the switch costs I would be a happy camper!
Old Jul 24, 2016 | 01:43 PM
The left turn signal does not flash... Does it stay on, or off? Does it function as a DRL, or not?
Old Jul 24, 2016 | 04:17 PM
You could take the switch out and hot wire the leads, then you would know. The BCM and wires is all there is between the 2.
I am not one who believes computers break in small ways.
Old Jul 25, 2016 | 07:40 AM
Drifter.'s Avatar
The DRL works correctly, the signal does nothing no light no flash.
What on the BCM could I check?
Old Jul 25, 2016 | 10:17 AM
The computer. That's why I said "I am not one who believes computers break in small ways." If they break they don't just break 1 small signal.
I would go into the switch and jump the wires to see if the switch is bad or not.
Old Jul 25, 2016 | 10:53 AM
I know you said you replaced the bulb, but did you verify that both filaments were good?
Old Jul 25, 2016 | 02:18 PM
Drifter.'s Avatar
Both Filaments were good on 2 diff. bulbs.
What wires do I jump exactly?
There are no trouble lights or codes showing up after a scan? This seems like a really dumbass thing, replace the cars computer to get a turn signal to work!!! What moron would design such a system......hopefully an unemployed one!!
Old Jul 25, 2016 | 04:14 PM
Check the harness wiring close to the sockets, it could be a wire was damaged if a previous owner had scotch locked a resistor into the wire for LED bulbs
