Lighter fuse
anyone know what fuse is hooked up to the center bezel? i had my GPS cord plugged in but it somehow got stuck in there and now it broke and there is a piece stuck right at the back of the lighter..it sparks at times since there is a piece of metal in there as well and touches the sides of the lighter if the car shifts.. want to get a needle nose pliers in there....or am i going to have to unhook the batter cables?
thanks
thanks
I think it depends on what year HHR.
My 2011 2LT shows #29 front cigarette lighter and #30 rear console power plug.
Both are 20 amp fuses so you could rob 1 to check the other out.
My front plug went dead last week and I just today took my tester out and checked it out. It was the fuse. Easy fix.
This is the fuse box under the hood.
SF
SF
skyline26-
My 08 is underhood fuse #29.. Surprised you haven't had a CEL.
My lighter shorted & blew the fuse (# 29) light went on instantly. Hooked up code reader & it said "No Link", because as (previously posted) this is connected to the ODB II socket.
He say it 'sparks at times' - so apparently the fuse hasn't blown (yet).
ya fuse is still alive nothing blown yet...just dont want to fiddle with the center bezel then unhook the outlet..thats too much work lol some pliers should do the trick as soon as power is cut to it or
No CEL when it went for me either ..... Seems I've read here somewhere that it is a very poorly made socket plug and subject to easy damage then requiring a complete replacement.
SF
Yes agreed..
That is surprising, (if you blew the fuse ? ) since the OBD II port is on the same circuit..
