Lighter fuse
Old Feb 25, 2013 | 12:56 PM
Silverfox's Avatar
Originally Posted by sleeper
Yes agreed..
That is surprising, (if you blew the fuse ? ) since the OBD II port is on the same circuit..
I have the fuse right in front of me and I can see it is blown.
How long would the CEL stay on after the event. If for just a short period I might have missed it although I doubt it. I pay close attention to all functions.
Old Feb 25, 2013 | 02:00 PM
ChevyMgr's Avatar
OBD port with a blown fuse will not cause a CEL. You just won't be able to monitor or communicate with the vehicles modules via a Tech II.
Old Feb 25, 2013 | 02:31 PM
Well, mine light up & fuse was blown by cig lighters' short to ground...
Coincidence ? edit: after further study, I have to believe it is a coincidence.
Old Mar 2, 2013 | 08:35 AM
gordon1's Avatar
power plug fuse
I also have a fuse that blows want to replace plug in dash. Hdo you get the front bezels out without breaking something thanks 2007 HHR lt
Old Mar 2, 2013 | 08:53 AM
grab into the air vents and yank.
Old Mar 21, 2013 | 06:21 PM
skyline26's Avatar
well so i pulled both fuses suggested and when i plugged them back in now i dont have power to my outlets..i tried replacing the fuses with new ones and still dont work..wat happened?? :s
Old Jan 21, 2014 | 11:25 AM
scbill's Avatar
Just found this thread.
If you decide to replace the well as I did, because there were burn marks(arcing) on the inside, also rust. If you go with an aftermarket (think autozone, pepboys,etc) before you start, get a couple of 7/8" ID X 1 1/4" OD thin washers, unless you can get the bezel off of the old port. 2006LT, underhood panel, #29=LTR(15A)front, #30=PWR outlet(30A)rear.
FWIW...If you are replacing with stock one, you may not have to remove the trim piece, look inside the well, you will see a grove, turn the groove to about the 1;o clock position, turn back, and forth while pulling out, the tab that holds it in place will line up with a notch and it may come out that way.
Hope this helps..Bill
Old Jan 21, 2014 | 08:36 PM
GM sells the OEM one for about $1 more than the ones you have to "modify" to work. There is also a special tool made for it.
Taunora
Mar 5, 2013 10:49 PM
Louvit
Jun 5, 2008 09:13 AM
NikiPowPez
Apr 27, 2008 11:49 PM
upOnGamE
2.4L Performance Tech
7
Jul 15, 2006 12:47 AM
Lee3333
Feb 1, 2006 07:48 AM
