Low beam headlights won't come on
Old Dec 27, 2013 | 09:07 PM
  #31
~shaking my head~ - check the light bulbs!!! Both low beams are burnt out.
Old Dec 27, 2013 | 09:19 PM
  #32
AIRMANBEAR's Avatar
I doubt that both went at once ..
And why don't the high beams work on auto setting ?
Old Dec 27, 2013 | 09:20 PM
  #33
Originally Posted by AIRMANBEAR
64 ,65 are ok ..thank you.. I will check relay 71 .. I didnt think it was the light bulbs because ..i noticed no lights would come on when it was on auto.. Unless ...i put the switch on manual override... Then only high beam would work.,..
Uh. Did you read my post?
I said you didn't post what year HHR you have.
64 ok? Read my post again. #64 does not pertain to the headlights.
Fuse #65,66 are the low beam fuses.
  #34
They didn't go out at the same time!!!! One burns out, and then the other - most people don't even realize they are driving with one burnt out, until it goes totally dark.
auto does not control it switching to high beam automatically!! that is why the highs came on when you "put the switch on manual override".
Old Dec 27, 2013 | 09:38 PM
  #35
AIRMANBEAR's Avatar
Yes i checked 65, 66 with a multi meter they are ok..excuse me i had miss stated the original numbers .. My memory ...??
Old Dec 27, 2013 | 09:47 PM
  #36
Fuses OK. Sounds like it's time to check the bulbs as has been stated.
If you don't understand how the HHR auto headlight system works, maybe you should read your owners manual.
If you don't have a manual, they are available for download "free" on this website. I would post you a link to the correct year owners manual download, but you still haven't said what year HHR you have( I know I asked twice)
Old Dec 27, 2013 | 10:06 PM
  #37
AIRMANBEAR's Avatar
2006 arent they all similar ..? Its minus 3 cel out and i have learned to check the easier things first before i go into the wheel well and pull the tire off
Old Dec 27, 2013 | 10:19 PM
  #38
Nope. That's why I asked the year model. The 1st year HHR, 2006, had a different setup. I believe it was only the the parking lamps that came on for the DRL system. (someone can clarify this if I'm wrong). The following years had the actual headlights for DRL's.
edit: Is this a Canadian HHR? If so, they seem to have a different system as far as the headlamp, DRLs are concerned. I'm not familiar with the Canadian version. Someone else would have to fill you in.
Old Dec 27, 2013 | 10:47 PM
  #39
AIRMANBEAR's Avatar
So if the light lever is left in the high beam position and in the auto position should the high beam lights come on when its dark and you start the 2006 and put it in drive ..?
Old Dec 27, 2013 | 10:50 PM
  #40
AIRMANBEAR's Avatar
No its a usa model
