Lug nuts wont come off???
Old Aug 19, 2017 | 08:02 PM
I keep an old chain link fence metal post on standby beside my tool boxes. It's about 5 ft long. It will slip over my 1/2 in. and 3/4 in ratchet handles. Just gotta use a little caution because that long of a lever will create some serious torque.
Old Aug 24, 2017 | 01:19 PM
Scouttster's Avatar
I used some heat from Mapp gas and it got cherry red.. They started sparkling like a glitter stick.. Smelled bad - like a huge fart after eating taco bell and ginger snaps.. All came off but I managed to snap 2.. I came to believe that some jock strap head overtightened them using an impacto wrencho... They're all back on now and suitable to remove should I have to deal with a flat on the hwy one day..
Old Aug 24, 2017 | 08:14 PM
Did you replace the broken studs already?
Anyone wanna bet they were all torqued down properly now?
Old Aug 25, 2017 | 04:23 AM
Scouttster's Avatar
Reply
Studs replaced..
All nuts torqued down with a 4 way.
Torque spec: 50 yo man bicep / forearm strength...
Hahahaha, I bet yall like that one.. Tips his ball cap..
Old Aug 25, 2017 | 08:42 AM
The proper torque is 100 ft lbs. with a torque wrench then checked at 100 miles.
Old Aug 25, 2017 | 09:23 AM
If you didn't use a torque wrench it doesn't count.
and heating stuff up till "cherry red" now leaves the remaining studs in question.
Old Aug 25, 2017 | 09:40 AM
X2. And the hub bearings could be damaged with that much heat. At the very least, all the old studs and lugnuts that were stuck should be replaced.
Studs that were severely overtorqued are probably stretched and weakened.
Old Aug 25, 2017 | 07:55 PM
Scouttster's Avatar
Reply
Thanks guys for all the help.
You guys are awesome!
Old Aug 25, 2017 | 08:11 PM
I think we can close this now.
Goose
Apr 18, 2008 08:35 AM
Goose
Tires & Wheels
Apr 5, 2008 09:14 AM
volcycle
Mar 18, 2008 08:49 AM
Rob
Oct 11, 2007 06:44 PM
GDZHHR
Apr 25, 2007 06:32 PM
