Misfire Mayhem
Old Jun 20, 2023 | 01:58 PM
  #41
PBwithJ's Avatar
...and make sure you plug it back in.
P0172 means the ECU thinks the trim required to correct an initial rich a/f condition is excessive. I think that could mean either the injector orifices are too big or they're leaking. That would also explain the hard starting. Do you still have your original injectors from the original motor?
I do but they were the source of the misfire
Old Jun 20, 2023 | 02:01 PM
  #42
PBwithJ's Avatar
Originally Posted by donbrew
However, the fact that you can smell the excess gas fumes would mean that the sensors are wrong and needlessly dumping fuel in. I am slow to blame injectors and computers for every problem.
A vacuum leak between the MAF and #1 O2 sensor. Brake booster hose, anything connected to the intake manifold, air tube to throttle body, any tube made of rubber under the hood etc.
Bad MAF, Bosch O2 sensor, purge valve not hooked up tight.
One of the most overlooked points is the air tube to the TB, it cracks where the PCV tube connects or does not get tightened down. Another is the brake booster tube.
I've sprayed starting fluid all around TB and hoses
i havent replaced the air temp or manifold pressure sensors... of course no codes for them
havent done water temp either... gauge reads fine ...
idk im out of ideas...
will update after i get new o2 sensors in
Old Jun 20, 2023 | 02:07 PM
  #43
Originally Posted by PBwithJ
MAF is brand new
What brand did you purchase? Was it installed in the correct direction?
mare there any air leaks under the MAF gasket?
Old Jun 20, 2023 | 02:22 PM
  #44
PBwithJ's Avatar
BlueStreak from O'reily auto... I have the Original I could swap to see if it changes
theres a notch so yes its in the right way
Old Jun 20, 2023 | 03:25 PM
  #45
I’ve had to switch back parts during a problem like this , try it
Old Jun 20, 2023 | 04:31 PM
  #46
The MAF and IAT are the same unit. Spraying stuff around the engine is fun, but proves nothing. Mark II organic light sensors work great in conjunction with Mark IV organic probes.
Old Jun 20, 2023 | 09:55 PM
  #47
PulpFriction's Avatar
You said in #11 "...i swapped injectors around and that was it so new injectors runs great!!!...
But you still had P0017 at that point. And it's too rich at startup, so not that great. I don't know how that happens with an air leak.
Could be a problem with the MAF sensor, but what new injectors did you get?
Old Jun 21, 2023 | 09:00 PM
  #48
PBwithJ's Avatar
alright so.... new up and downstream o2 sensors... the p0172 fuel trim system rich... it returned.
with all other ideas exhausted, I removed and cleaned the throttle body, idk it appeared spotless inside.
also, the air temp sensor I sprayed out with MAF sensor cleaner.... so far p0172 hasn't returned, it usually returned after about 30 min of running so far hour and a half at idle couple runs down the road, so fingers crossed!!!!!
BUT.... still long start after it sits.
it did have to turn over 8-10 times before,
with the new fuel pump only 3-4 times so it made a difference.
both evap purge and vent solenoids replaced, and there's no inline filter idk what else it could be.
Old Jun 21, 2023 | 09:04 PM
  #49
PBwithJ's Avatar
while i was waiting for new "Ultra-Power brand" injectors i corrected the exhaust cam gear I had installed a peg off..
Old Jun 21, 2023 | 09:42 PM
  #50
Quick check, after it's been sitting and you're expecting a long start, turn the key to "on" but not to start. This will initiate the fuel pump. It will only run for about 2 seconds before it times out with no start sequence initiated. When you hear the pump turn off or after 3 seconds turn the key off. Do this twice. This is to build the line pressure to normal. Then start as normal and see if the long start is unchanged, worse, or gone. Wondering if your fuel pump check valve is working. (Wasn't this discussed already?)
I'm also suspicious of your new injectors. To clarify, did you or did you not still have a P0017 at the time you changed those injectors?
