missing coolant
One thing you could try, is pull the dipstick out of a hot motor.. Wipe it on the exhaust manifold. Oil will not bubble or sizzle. Coolant will..
Oil will only smoke & smell..
Welcome to another meeting of the "I've got socks older than some members club". I was going to suggest just what you suggested sleeper, then I remembered that you need to be double jointed to get to the exhaust manifold on the HHR. Grandpa taught me that trick when I was maybe 8 years old and helping him with the Farmall tractor.
I can understand you not wanting anyone else wrenching it.. But if Ur getting coolant in the oil. Time for a hand-off to the Dealer. It could be quite expensive, depending on the findings.
Anytime asanti, some of us here are full of useful info like how the set the magneto up on an Allis Chalmers tractor, or replacing the spring in a Victrola. All kidding aside, I'm a firm believer that the day you stop learning is the day you stop breathing, I pick up knowledge here all the time.
an appoinment is made at queenston chevy for fri afternoon. as far as cost, a head gasket job is not unreasonable , even if i were to do it myself. my main concern is how long its been leaking. weve had the car for 6 weeks and the coolant was low when we got it. how long has it been leaking into crankcase and what damage has the coolant done to rod and main brgs. coolant and bearing babbit dont play nice together. hopefully i can convince them to r&r a rod brg for inspection. i dont think the mains are accesible cause of the split crankcase design. me thinks that requires an engine r&r.
as far as dropping some on a hot exhaust, i dont think there's enough coolant in the oil to notice any sizzlin. the few drops i detected were pinhead sized. good idea though. just like dropping frozen fries into a deep frier.
hi sleeper
Not trying to rain on your parade. Just making you aware !!
