My HHR is hazard to road safety!
Old Oct 17, 2021 | 06:44 AM
  #41
AZHHR77's Avatar
Exclamation Try this instead?
Problem Solved for most HHRS - I am not trying to say any other post is wrong, I am only writing this to save everyone else the problems I had. I have read 300+ posts and almost no one had the answer. Even now, I had trouble finding the exact solution even though I knew the answer. I have two HHRs, both had a Reduced Power Message displayed. Sometimes there was no code and other times it had different codes. Most posts indicate a problem with the Throttle Actuator Control (TAC), the TPS sensor, or TPS pedal switch, which doesn’t solve anything. The Reduced Power Message points to too many other components (which I checked numerous times) when really it has to do with the 5-volt reference wire (that feeds 6 other sensors) causing a misdiagnosis. The REAL PROBLEM lies in the pass-through connector for the fuel pump, located under the vehicle and in front of the left rear tire. I would have never imagined or found it without another mechanic’s help. One or more pins in the connector has some corrosion causing a bad/intermittent connection. Mine was caused by a leaking ice chest and/or a wet blanket behind the rear seat. The connector isn’t watertight on the inside of the ​​​​​​vehicle, so the moisture enters from the backside. As soon as I unplugged it from under the vehicle, I found water inside it from months earlier. All I did was clean out both ends of the connector and it has been perfect for over a year. Since the issue is usually intermittent, making a bogus repair to anything may look like a fix, but it’s not. Also, this repair is easy and costs nothing.
Sundance
Feb 25, 2014 09:11 PM
HWD510
Sep 11, 2013 06:25 PM
drummerboy0088
May 30, 2012 09:54 AM
Yonash
Apr 26, 2011 11:36 PM
