AC is it a TXV?
Old 08-27-2018, 02:21 PM
haX0r's Avatar
AC is it a TXV?
Finished my LCA and links (went almost too easy: scared!) Brought in for an inspection and alignment. (They said I did a nice job on the LCAs and should submit an application. I don't see how they can tell I did a good job. But I'll stick to fixing CNC lasers; a LOT more fun and challenging.)
But they brought me out to show me the 'green' on my AC compressor, stating its probably leaking. (dang)
I do have a type 1 HVAC lic, but only got it to work on my own stuff. So my overall question is does the HHR (2006) have a TXV or fixed orifice metering device? Just need to know if I have to shoot for sub-cool or super-heat.
TIA,
haX
haX0r is offline
Old 08-27-2018, 04:11 PM
Technical Moderator
Is that in English?
donbrew is offline
Old 08-27-2018, 06:59 PM
tiapetra's Avatar
Your car has a TXV
You can still check both subcool 15-20° or superheat approx 15°
Or if it's empty best to just weigh it in.
tiapetra is offline
Old 08-28-2018, 02:34 AM
Cat Man HHR's Avatar
Didn't understand at first what this is about. Looked up TXV which is an acronym for Thermal Expansion Valve.
Then I found a video that explains superheat and subcool.
Cat Man HHR is offline
Old 09-06-2018, 04:55 PM
Blue_SS's Avatar
TXV. Confirmed.
Blue_SS is offline
